Ok, here's the story. I have had my Sony 65" RPTV (KP65WS500) for about 13 months now. I started to get the dreaded Sony flicker a few weeks ago. I did some research and found it was a known problem and not really a big deal to get fixed. I called the service center and had the service guy out. He checked it out and agreed that the CRT's needed to be replaced. About 10 days later my CRT's arrived and I had the service guy come back to install the new tubes. He brought another tech with him because he said it was a 4 hour job with two people. After looking at the TV again, it was deteremined that it was the red CRT that needed to be replaced. They said they only liked to replace the flickering CRT, not necessarily all of them. After a little questioning from me, they started the job. It took 10min for them to replace the CRT. They calibrated the set through the service menu. The flicker stopped, but I noticed a "red shadow" on the left-hand side of the TV. The techs couldn't really see it, but they messed with the convergence for a while longer then left. The red permeated the left side of the TV and I decided I couldn't live with it. I called the service center and had the tech come back out today. He came back and looked at the TV for a while. Finally, after I convinced him it was not just me, he checked the convergence again. It was off a little. After re-doing the convergence, the red on the left-hand side was a little better, but still visible. He finally took the front off the TV and started to adjust the gain and focus knobs of the red CRT. After some fiddling he got the picture a litle better. He tried to tell me the problem wasn't there any longer and that there is always a little difference in the color across the screen of an RPTV. He left and I decided the picture was a little better. This evening I sat down and watched a movie. I noticed in some frames that are completely black (cut-aways) that there are red lines across the screen evenly spaced about 3" apart and slightly curved towards the middle of the screen. The black also has a slightly reddish tint.
Sorry for the long description, but I figure I may as well cover the whole story. Now, my question is this, would changing just the red CRT cause some of these issues? I am convinced that the red CRT is brighter than the 13 month old green and blue CRTs. The tech said it should not be an issue. He said there is not really a brightness difference between older and newer CRTs. I have no experience with these things. If there are any experienced repair techs or ISF calibrators, I'd appreciate your opinions. I don't think I'm going to be able to live with the set as it is now. The picture is not bad, but I'm a perfectionist and don't really like having things that aren't perfect, especially $3,000 things. Should I have the guys come back again and insist they replace the green and blue CRTs? Would a professional calibration correct some of these things? I'd hate to pay someone hundreds of dollars when the service calls are still covered by my extended warranty. Your thoughts are welcomed. Thanks.
