Status
Not open for further replies.
1 - 4 of 4 Posts
Well I have a problem.
We recently purchased a home, and with the home came a 52 inch RPTV.
That isn't the problem. The problem is, due to room/view/fireplace/wife locations I am forced to have the TV in a corner. This makes it very difficult to mount my rear speakers. Luckily there is enoough room to walk behind the sectional couch.
I have attached two drawings, one shows the current setup, and the other shows the proposed setup (only involving re-locating the rears).
Does anyone have any advise, or opinions about my setup?
The current setup doesn't work, and I need to change it asap.
Speakers: Energy take 5 (small speakers)
Reciever: Marantz sr5200 (with time, and distance delay for all five speakers)
Thanks for your help!
JR
Discussion Starter · #4 ·
Originally posted by gregpr
what about moving both rears to the dining room wall?
Does the receiver have the same adjustment menus that allow you to specify distance from a 'sweet spot'?
Hmm, I could try that.
I am able to set the distance (and delay) for each speaker from the listening postion.
I wonder if your idea would cause any imaging isuues with the front speakers, or if the delay/distance settings would take care of that.
Only one way to find out though....
1 - 4 of 4 Posts
Status
