Need help with speaker setup!!!
488 Views 1 Reply 2 Participants Last post by  crazyrob425
Need help.. I'm about to order a pair if BIC Pl-89's for fronts and the Pl-66 for surrounds. My problem is I don't have the room to fit the Pl-28 under my tv, so I was wondering if I got the Pl-26's would that be a ok as far as voice matching and everything?
1 - 2 of 2 Posts
Should be able to make due with the PL-26 since the tweeter is same but why not just stick with the PL-76's? If you got a subwoofer handling the lower end you will have little use for the PL-89 bass response
1 - 2 of 2 Posts
