Status
Not open for further replies.
1 - 2 of 2 Posts
Help! I just purchased an Onkyo 797 a month ago. I had everything setup and working. All speakers tuned in and sounding great. Saturday I noticed my active sub sounded very flat and the bass was very loose. I checked some settings, changed out the cable, moved it to another power outlet and nothing. The bass sounds very sloppy, not tight like it normally is. I tried another active sub off the same sub pre out from the amp and same thing. Horrible sounds, the cone of the woofer is jumping further than normal as well. I moved the sub upstairs to a Pioneer amp and using the same cables the sound is like it should be. What could be wrong? Could the pre out be bad? Please advise.
Discussion Starter · #2 ·
Any help?
1 - 2 of 2 Posts
Status
