1 - 6 of 6 Posts
· Registered
Over the past year i have purchased the RF-62 surround system from Klipsch. I have a Harmon Kardon Receiver and a sub 12 subwoofer by Klipsch.
I have a 50" Samsung LCD Tv that hangs over my mantle. What i need help with is i am about to have all the wiring ran and i would like to put all my components and satellite box on shelves that are in the basement. I already have the tubing ran so i can feed the wires to the television.
The wife says that she doesnt want anything else on the mantle or on the tv, so that means no ir repeater system.
So my question to all of you in the know is what else are my options?
· Registered
not sure what ir distribution has to do with surround sound...
but...
i would look to a rf solution....
also...
you'd be surprised at how easily you can hide an "ir eye" to feed a repeater...
· Registered
Harmony 900 or 1100 remotes work off radio frequency (RF) so do some Phillis pronto remotes and URC brand to name a few.
May I suggest you get your wife to let you keep the blu-ray player on the mantel so every time you want to pop a movie in you don't have to run down stairs.
1 - 6 of 6 Posts
