Status
Not open for further replies.
1 - 10 of 10 Posts
I'm building a home theatre and I need some advice on the best setup. Pretty typical question I know.
http://24.76.29.138/stuff/layout.gif
Here is a floorplan I did in visio with my ideas of where i would put everything. Notice that back dividing wall is not in yet. The room is 12' x 23'x 9' right now. I want to build it up for THX Ultra II, I was thinking of using Energy speakers and the Pioneer 7.1 amp.
I wanted the theatre to run using a HTPC, with a firewire DVD drive and a RF keyboard and mouse in the theatre room.
That's the rough idea. Does anyone have any advice about speaker positions, wattage, screensize, etc. for a room this size?
I don't know if you've already settled on CRT or Digital, but one huge advantage that I see with this layout is that you can mount the projector as through-wall from the equipment room. In fact, if you make that back room just a little bigger, you could make it your snack area. Then, you'd have a layout just like mine:D
Seriously, I ran into some dumb luck with this layout. I just happened to use a "false" ceiling in my rear snack area. This has been a major advantage since I've upgraded my projector cabling 3 times. And, since I moved the projector (DILA) from the Theatre seating area to the snack area, I don't really have to worry about heat or noise.
(OK. So maybe I still can't store chocolates near the D-ILA exhaust, but at least I didn't have to build a hushbox)
Just a couple of thoughts:
  • Big screens are cool. You probably have enough width for an 8' wide screen.
  • Would you rather have room for another row of seats or the equipment room?
  • Does the entrance have to go through the equipment room?
  • What about reversing the layout so the screen wall is at the bottom? That would give you a little more width at the front.
--Burke
I agree with Burke on the entrance issue. I would put up a wall with another door between the main entry door and the equipment area. Could you move the main door to the left to seal off the equip area, and just have an entry way with no door where the main door was. This would seal off the equipment, so that you didn't have to see it when entering the theater, and it would form a small lobby entry way that you could hang a now playing poster on, opposite of the door leading into the theater.
Remember for the BEST possible picture and TRUE blacks CRT is the only way to go,
ts
How wide of a screen do you want? How many seats?
I ask because the wider you want the screen, the further back you will have to sit. The more seats, the more rows (and you don't want any rows against the back wall) Based upon the answers, you may need to make some trade-offs.
--Burke
A couple of thoughts:
1. It appears your seating distance is around 17'. A 96" wide screen may be to small. Seating distance of 1.5 to 2 x screen width are typically recommended.
2. Don't forget all the other details in addition to layout, ie, soundproofing, acoustics.
3. I don't think the subwoofer located in the cuby hole is a good idea.
If you haven't been studying this subject for a while, I would go slow until you learn more. (Sometimes we learn more than we want to though :) )
My room measures out to be 21' long and 14' wide, so it is pretty close to yours. Since I have 2 rows of seating I wish I had another 3-5' in length.
The rear seats (on a riser) are only 2-3' from the back wall and I think they need more space for the dipole surrounds to really sound best. The lower seats are at a better distance but end up being about 12' from the 8' wide screen and that's just a little close for my taste.
You will be able to get the best placement of acoustics and video if you only have to deal with one row. Once you get into trying to balance 2 rows of seating, walking space, speaker placement, etc. you will end up having to make some concessions.
I think the idea of placing the screen at the other end of the room really opens up options. My HT is 25' long and easily has three rows of seats so two rows in that space should be easy. I do disagree with the seating distance. This really is a personal thing I think. My front row is about 10' back from a 9' screen. If the source material will support it ( HD or good scaled DVD) this is by no means too close.
Art
1 - 10 of 10 Posts
Status
