This is my first foray into using a pc as a PVR. I bought Sagetv with Zapstream remote + Wintv 250 tuner + USB-UIRT
I feel a little out of my depth bc the instructions were only how to install each item and not how they all work together.
Anyway my biggest problem is that the USB-UIRT is not changing dishnet channels. When I teach the UIRT the remote codes 0-9, it says it works. However, when I try to use the zapstream remote or the EPG to go to a channel, it doesnt do anything.
Is there some special way to teach dishnet remote codes to the USB-UIRT? I have the old dishnet 3750 receiver (which is a QAM receiver bc it is a multi-dwelling commercial install of dishnetwork) I found that Tivo could not control this receiver so went to the pc PVR route.
Thanks for any help
Thanks for any help
