I'm trying to get the best possible picture (aren't we all) out of this thing, and I hope to pick the brains of some other forum members who have vt540s.
I am using a Tosh 5109 progressive player thru component to drive it. I also have some s-video sources like a Dish Network receiver and a Dreamcast. I have an Iscan v1, but I find the picture looks better without it. Projecting onto da-lite tripod mounted glass-beaded screen, 70x70.
Anyway, I calibrated with Avia last night, and I'm pretty happy. However, there is a slight yellow emphasis in certain scenes. Yellow objects seem oversaturated with yellow, if that makes any sense. I know how to (try to) eliminate red push, but not yellow push. Ideas?
Further, what settings are you using for Noise Reduction? I set mine to Off. I have aspect ratio set to Cinema (for anamorphic dvd's) and Normal for s-video sources and full-frame discs. For (forgot setting name) I'm using Normal instead of Natural 1 or 2 because I thought it looked, well, more natural.
Color matrix is SDTV, and type is Cr/Cb. Should I be using something else?
rick
[This message has been edited by rickforrest (edited 04-20-2001).]
rick
