1 - 5 of 5 Posts
Hi guys,
Just to give you a quick recap on situation. I recently built a new house and had my dealer run the wires pre installation. I have a budget around 10-12k for everything. Including screen, projector, speakers, sub, receiver, av rack.
I already have the furniture so the 10-12k will go into the audio/video and installation which will be around 1,200.
These dealers use epson and JVC. For sound they use Paradigm, Triad. For screen selection you have Da-lite or Stewart. Yamaha is the reciever I think I am going to use as well. " from doing my research on here It looks like I will purchase my sub separately from SVS since it seems you get more bang for your buck over paradigm."
Please I need some real help with this. I want to get the most bang for my buck. Also I should let you know that the system will be at least 7.1 and I think that the surround and rear speakers will be ceiling. Is that bad to do? should I get them to do wall instead? The front speakers will def be in wall? The size of the room is about 20x20 with 9foot ceiling. There is one small window on the right side of the room that is about 2ft wide and 3ft tall, but it will have a blackout curtain or shade on it at all times.
Need some expert opinions as soon as possible, these guys are ready to order and install.
Originally Posted by madmartigan10  /t/1520748/need-help-with-yamaha-receiver-selection-in-new-media-room#post_24433312
would a yamaha rx-a830 be able to handle that as well. Might not be able to swing the more costly reciever since i am on a budget.
I'm pretty sure only the top 2 models (rx-a3xxx and rx-a2xxx) can eq dual subs.
Originally Posted by jcwhammie  /t/1520748/need-help-with-yamaha-receiver-selection-in-new-media-room#post_24433356
Correct, only the two top models do EQ the subs. However the A730/830 as well as other models from the RXV line-up do have dual sub connections. You can always set up subs the old fashion way, tune em till you like the amount of bass is where you want it. We went years without Eq programs. There is also the HTR models from Yamaha that also have very good connectivity and sell for less than the RXV and the Aventage models.They are equal to the RXV line. Go to Yamaha's website and do a compare between the RXV and HTR series. Good luck and hope this helps stay in your budget.
1 - 5 of 5 Posts
