1 - 5 of 5 Posts
Hello everyone,
Yesterday, I was able to buy Yamaha - RXV765BL for under $400. I bought it because after doing some research, I found out it was one of the best mid range receivers available and had a huge discount. Now, after doing some more research I found it there were some HTIBs that could be just as good and with speakers + cheaper after assembling.
I have the following questions:
I have around $400 cash to spend on speakers. Is it enough to get all the 7.1 sound system set? If not, what would you recommend as a must have speakers before getting the complete speaker 7.1 set.
Also, how does the HTIB, the two that I have in mind compare to this setup. Both HTIB that i have in mind are ONKYO HT-S7200 and YAMAHA YHT-791BL.
Also, are these speaker Polk RM6750 compatible with the receiver Yamaha that i bought ?
My use for the Home theater system are:
PS3 - Games & Blue ray
Directv HD Sports and Movies
Computer - very ocassional gaming.
Room size: Normal Living room
Thank you
Nice receiver purchase!
Yes, the RM6750 speakers are compatible with your new receiver. But in a normal size living room I'd prefer something bigger than little satellite speakers. Are little sats as big as you can go? I guess not since the Onkyo system comes with tallboy speakers up front.
As far as getting a 7.1 setup, does your room allow you to place 7 speakers properly? The rear speakers need to be at least 3 feet behind the main listening and placed above it too. You might be better off you going with a 5.1 setup, especially for a $400 budget.
http://www.audioholics.com/tweaks/sp...ssential-guide
Since you can get towers, consider something like this.
http://www.vanns.com/shop/servlet/it..._c=site_search
And then add a $150 subwoofer
http://www.thenerds.net/BIC.BIC_Amer...1020%5E~%5EBIC
If you want smaller speakers all around consider the C401 bookshelf speakers from Jamo. Vanns.com has a great deal on them right now.
matching center
Define normal size? I had a normal size living room in NYC and it was 9 x 10 and now I got a normal one in the suburbs thats 13.5 x 14.75
I use the RM6750 and I think its a great speaker package and very under-rated it has no trouble filling my room
1 - 5 of 5 Posts
