Hello everyone,
Yesterday, I was able to buy Yamaha - RXV765BL for under $400. I bought it because after doing some research, I found out it was one of the best mid range receivers available and had a huge discount. Now, after doing some more research I found it there were some HTIBs that could be just as good and with speakers + cheaper after assembling.
I have the following questions:
I have around $400 cash to spend on speakers. Is it enough to get all the 7.1 sound system set? If not, what would you recommend as a must have speakers before getting the complete speaker 7.1 set.
Also, how does the HTIB, the two that I have in mind compare to this setup. Both HTIB that i have in mind are ONKYO HT-S7200 and YAMAHA YHT-791BL.
Also, are these speaker Polk RM6750 compatible with the receiver Yamaha that i bought ?
My use for the Home theater system are:
PS3 - Games & Blue ray
Directv HD Sports and Movies
Computer - very ocassional gaming.
Room Size:
I'd say is about a normal sized living room.
Thank you
Room Size:
Thank you
