Status
Not open for further replies.
1 - 1 of 1 Posts
HI, I am putting togather an HTPC on the cheap and I have been able to round up the following so far.....
AMD 64 3200 w/Thermaltake Heatsink
256mb GForce 5600 w/DVI out
1gb ram
mATX K8M800 MB
AVerMedia's 180A HDTV card and PVR 150
250gb HDD
NEC 8x dual layer dvd writer
MS MCE Keyboard
MS MCE Remote
Obviously one thing is missing... a freakin CASE (which I do not mind spening money on as they should have a longer lifespan)!!! It must be @ or under 15.6" in depth, width and hieght do no matter. Also it needs be able to fit all the equipment listed above. So ANYONE have a suggestion for a PC case that fits all that criteria.... if so
THANK YOU MUCH!!!!
-Me
1 - 1 of 1 Posts
Status
