1 - 10 of 10 Posts
Discussion Starter #1
Hey guys, I want to set up a BYT this summer using a 16 x 9 ft screen with a rear projection setup. I'm unsure of which projector to get though. I'll be showing movies during the evening and at night, so I need something with enough lumens to light up a screen of that size as the sun is setting or has just set. I have budgeted $15,000 for the projector, but am willing to go up to $18,000 if I need to. I'll be using the Open Air Cinema inflatable screen.
http://openaircinema.us/outdoor-mov...o-screens/16-open-air-pro-screen#.VTcOTZY8LCQ
Any advice would be greatly appreciated!
I would look at a high lumen single chip DLP. Something like a Dvision 30 Series from DPI. If we can help you, give us a call.
SIM2 has a model...the SIRIO...that's spec'd at 7000ANSI and which should fit into your stated budget. It's available with a bunch of lens options, including a super short throw that would be ideal for rear projection applications. I think Christie also offers something in this category.
Discussion Starter #4
Great, thanks for the info guys, I'll look into the SIM2 and the Dvision 30 series. Appreciate the advice!
I was just curious if it might cut them down a bit. I've never seen a high end DLP on a rear projection screen before.
I have seen a bunch of rear projection setup's, but I don't see rainbows, so I could not tell you if it makes a difference or not. My opinion is that it does not change the rainbow effect.
As picky as I am, I never noticed rainbows on the Samsung RPTV 1080p DLPs some of my family members used to own.
Hi, I would consider starting out with a less expensive, used projector to make sure this setup meets your expectations.
take a look at the Infocus IN5535 which was made for large venue use. You can pick these up for around 3K on Ebay from reputable sellers.
info on the projector:
http://www.infocus.com/projectors/IN5535#overview
This auction ships with 2 brand new lamps
http://www.ebay.com/itm/InFocus-IN5...Projector-6000-LUMENS-NEW-LAMPS-/291404543710
1 - 10 of 10 Posts
