Here's yet another HVAC question. How should the HVAC contractor size the HVAC for my HT? I guess he would need to know the heat load for the room? This is an area I know very little about.
My room will be no bigger than 19'x37' counting an odd space at the back and we plan to having 2 rows of 4 plus a bar at the back. We are planning to leave the basement unfinished initially, but I want to make sure the HVAC is sized appropriately, as it will be cheaper to do it right now, rather than add an extra HVAC unit later. I think our particular HVAC contractor prefers to use a single unit with multiple trunks, dampers, and variable speed blowers as opposed to multiple units. However, they do model the entire house, so it's not a jack leg company that just uses the square footage to size the unit.
I appreciate the advice.
