Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
I've found the Sony SAT-A65 and RCA DRD485 & 486 have rf remotes. Does anybody know if these integrate the OTA channels & sat channels into the same guide? Also wondering if there are any other newer SD receivers that have rf remotes....
Mark
· Banned
You can add to your list of SD Ir/RF remotes the Hughes GCAEBOA, however, all of the ones you listed and the Hughes have been discontinued for about 1 year and DIRECTV does not have any SD RF remote IRD's any longer.
The only current Ir/RF STB is the RCA HD DTC-210. The only way to make a SD STB's remote to work RF is to buy an RF sending unit like the RCA cones.
-Robert
· Registered
Discussion Starter · #3 ·
Robert,
Thanks much for the info. I thought I read somewhere that the Hughes unit was same as the SAT-A65.
Does anyone know if these receivers integrate the OTA channels & sat channels into the same guide?
Mark
1 - 4 of 4 Posts
Status
