If you gave us your zip code that would let us give you some better ideas as to what might work...
Originally Posted by Turbo DV8 /forum/post/12926374
Long story short ... New to OTA HDTV. I have a 140" boom length antenna with a gazillion elements, give or take. Have rotator, will travel. Got good signal until storms a couple weeks ago, then the signal was all over the place. Thought I need some amplification. Weather cleared, then raised mast 7 more feet ... added mast-mount amp. Worked great until next storm, now it dawns on me that likely the wind whips the antenna/rotator gears back and forth a couple degrees and wreaks havoc on my signal. So during storms I have an amplified bad signal ... wonderful. Someone suggested perhaps my long antenna has plenty of gain as-is, but also is too directional, hence slight movement in antenna disrupts signal acquisition. So I am in need of a much less directional antenna, and need suggestions.
I want to keep the original antenna on the rotator as-is, and add another less directional (omni?) antenna lower on the mast, and be able to select from the two with an indoor switch. I need an antenna that is, 1) omni or at least 180 degrees coverage, and 2) able to cover not just UHF but also VHF, as in my area two stations will still be using VHF in 2009. I purchased a Philips MANT940 to play with, but haven't tried it yet, as my gut says it's likely a waste of time, and also no VHF capability. Suggestions for an antenna that fits the above requirements? Thanks.
