Hey All-
I finally started programming my 3 month old MX-980 remote (don't ask why I took this long to start
) and I'm running into a snag on learning / programming 2 remotes.
One on of them it's for an Universal System Selector Pro. I taught the commands to the 980 via the unit remote and it said it learned them (via 1 click and then 2 click learning) but when I download and test I get nothing. Thinking that the battery might be too old I tried learning it from my old MX-850 that's dieing and still nothing. Do I need to buy a brand new battery for this thing? It is an IR remote as it works on my 850.
I also opened up in the Universal Browser the file from RemoteCentral called Logitech Harmony PS3 (Newer Prontos & URC).ccf and placed the commands on the hard and soft buttons I wanted.
Once I was done, downloaded, tested and nothing. It still works via the old 850 so it's not a hw related issue. I also tried teaching the 980 from the 850 but that was a no go as well. I might try dragging the hex codes in (which I believe I did it that way for the 850).
Help please. I finally after 8 hours got the hang of this new remote but these 2 issues are confounding me.
