1 - 7 of 7 Posts
I need a reasonable price but good projector:
Here is my set up
1) my screen area will be about 100 inch
2) the projector will be ceiling mounted
3) It will be hooked up on an iMac as the media center
Here is my set up
Is that 100" diagonal or wide?
Do you have a set budget as Jim mentioned?
How far will you be sitting from the screen?
$500 to $1500QUOTE]
That's quite a range to pick from! $500 will only net you something used maybe 720p if you are lucky, while $1500 will put you into some nice 1080p systems. If you have the money to spend at the higher end, you will be VERY happy with the result. Make a DIY screen and you have something great for very little money.
EDIT: Sorry, I referenced another thread thinking it had valuable info, but it was mostly people getting into a p*ssing contest. There are several good choices out there.
Will you have some lights on, or will you generally be watching in the dark?
1 - 7 of 7 Posts
