I need a recommendation for a new TV set.
-Major gaming use, (competitive fighting gamer here) so low to nonexistent input lag is the biggest priority. I really want to dual monitor tests; the usual "I dont feel any lag" isn't going to help. Absolutely no more than 16ms lag over HDMI. Low to nonexistent latency over component (480 and 720) and VGA is also needed, but can be over 16ms if needed.
-Minimum of 58", with 65" preferred
-No projection of any kind.
-No preferences on technology (LCD, LED, Plasma)
-Not a 100% stickler on picture quality, so if the same latency requirements are met on a cheaper model, I'll go with the cheaper model.
-Max $4k-ish. I can't swing the massive large format computer monitors or I'd be doing that.
So please, can anyone point me in the direction of a model of a 65" tv with the absolute least amount of input latency?
