I need some help figuring out my best option. I’m 25 miles from the broadcast towers on Mt. Wilson and I can’t pick up VHF channels with rabbit ears indoors (7, 9, 11, & 13) even though I'm right in the heart of a major metropolitan market. My TVFool data is attached. I have a big window facing in the right direction and I want to put something up that will do much better. I’d rather not drill holes and put an antenna outside so I’m looking for my best option to hang in my window (and cover with a curtain).
I originally wanted to hang a big antenna in the window but I learned in another thread about how I’d need to consider the polarizations used by the local stations – i.e. many VHF antennas need to be mounted horizontally or they don’t work properly. This is a report I got from another member:
CBS 2 [43] -> Horizontal
NBC 4 [36] -> Elliptical
KTLA 5 [31] -> Elliptical
KABC 7 [7] -> Circular
KCAL 9 [9] -> Circular
KTTV 11 [11] -> Horizontal or Elliptical (Requires upgrade)
KCOP 13 [13] -> Horizontal or Elliptical (Requires upgrade)
KCET 28 [28] -> Horizontal
KOCE 50 [48] -> Horizontal
So I came across the Winegard HD-1080 and it seems like my best bet so far. It was intended to be mounted vertically (and it would fit perfectly in my window) but I’ve been reading some poor reports on its ability to receive high VHF. I’m wondering if there’s anything better for my situation or if I should give it a go for $30.
Please, any input is appreciated. Thanks!
EDIT: No matter what the TVFool report says, a "set-top" antenna is NOT sufficient to pick up high VHF channels. I've tried so many ways to pick up these channels, 9, 11, & 13 in particular, it's practically impossible for me even though there's only a two story building standing in the way of my LOS. I live on on a 'kind of' hill - or - I'm in a better situation than most Los Angelinos in the LA basin for LOS to the broadcast towers. I'm on the 'Westside' if that matters.
