Status
Not open for further replies.
1 - 5 of 5 Posts
Losing my Tosh. 34" direct view and adding a front projector for dvd. Need
a fairly compact little interlaced set to watch news, sit coms and so on
off of local cable. No interest in hi def right now. Is there a particularly good choice in this smaller size range? Something that will calibrate up with
Avia for a decent picture. Thanks in advance for any ideas before I hit the
streets shopping.
My KV-13FS has a good complement of service mode settings. I think you can assume that other recent component-input Sony's will have a very usable service mode. You could try keying in service key sequences on the remote before you buy.
Discussion Starter · #4 ·
I'll check out your recommendations.
For about $325.00 you can get a nice 27" jvcd303 which is not a flat screen but is a good picture and alot of adjustable sttings in the menu. If you have to have a flat screen check out toshiba, sharp,and jvc. I personally have a 20" toshiba flat screen and it's fantastic!
1 - 5 of 5 Posts
Status
