1 - 2 of 2 Posts
Discussion Starter #1
Looked long time for a specific cable (black/green/orange)to logitech z-5500. I was told the only thing for me to do is to buy 3x3.5mm male to male plugs, strinkwrap and paint them the colors. Was wondering if I will be better off just buy a coax or optical cable. I have onboard sound and a SPDIF output in my pc and will it be better sound than the analog plugs. Thanks!
What you've been told is correct, but I wouldn't bother with the shrink-wrap or painting.
Digital will have some restrictions if your PC doesn't have DDL/DTS:C.
1 - 2 of 2 Posts
