need replacement speaker for paradigm 11s
281 Views 1 Reply 2 Participants Last post by  lazyhaze
Hello, I have paradigm monitor 11s for my fronts and I also have a 3 year old.
Ok by now you guys know where this is going:(
I had the grills off for just a minute, and them 2 had a run in.
The little bubble on the speaker just to inviting, he couldn’t resist.
Anyhow he pushed it in it’s smashed in.
So I guess I need to replace that speaker.
So my question is, what do I replace it with?
Does it have to come from paradigm?
Where can I get it from?
I am asking because if I go to a paradigm dealer I am sure I will get soaked.
Any advice would be appreciated.
See less See more
Status
Not open for further replies.
1 - 2 of 2 Posts
Do you mean that he pushed in the dust cover on the woofer? or that he actually put a hole through the speaker?
I have heard many speakers with pushed in dust covers, and have never heard a difference in sound quality. It is ugly, of course. I would not recommend replacing the woofer with anything other then a paradigm speaker as it would not match your other monitor 11 anymore if you just put an OEM driver as a replacement.
1 - 2 of 2 Posts
Status
