Need Router Help
2515 Views 33 Replies 15 Participants Last post by  Derek K.
My htpc is my living room however the my main computer with 2tb memory is in the study. I want to stream hd mkv's to my htpc. I have read that my only option to do that is an N Router.
The issue is that all laptops in my house have g wireless adapters. I know N is backwards compatible but would running a laptop with g network adapter and htpc with N network adapter hinder the speed in anyway.
If yes by how much.
1 - 20 of 34 Posts
AFAIK, wireless may not work. I have tried to stream BD ISOs over a Wirless N Bridge and the bandwidth is just not enough.
Maybe somebody here has had better luck with MKVs.
Running a cable is the best solution, IMO.
Also, even if N works for you, any G devices on your network will pull your network down to G speeds.
MKVs dont help either.. I have tried everything even in the same room using N - H.264 was not too bad - VC1 forget it.. no way and this was with FLAC for audio. Now I was using the 2.4 Ghz which is ridden with interference.. The 5Ghz N may be better. Again, generally wireless is only good for HD with no interference at short distance...
I gave up and resorted to running ethernet CAT6 (since I was running cable why not future proof)..
Is this true????can you quote any sources because i think this is not the case with n router.
if it is, that's just dumb engineering...
3
If yes by how much.
How far from the LR to the study? My solution foir HD throughout the house was hard wire and a Gig-e switch. Buy the cable on ebay and get a good switch from the EGG. Going wireless will be continuous headaches. Run the wire and be happy.
See less See more
This was the case with G/B. Even if you are running a G AP, any client B will "pull" everybody down to B speed.
Dumb or not, that's the way it is.
Of course one can have multiple APs. One dedicated to N, and another one servicing the Gs.
But I gotta go with everybody else, run a cable and be done with it.
See less See more
It's called mixed mode it and your speeds will be slower then straight N. I run 2 routers, a G and N at 5 GHZ side by side to avoid this. 5ghz N will stream HD fine for up to 50-75ft maybe longer depending on what bitrate your streaming , the problem is at 5ghz the signal drops off faster then 2.4 and dosen't pentrate walls as well. In the end, I still have the two wireless routers, but I also ran Cat 5 across my house because the bluray .iso's were stuttering badly.
Now to revisit my problem again and a possible solution I have come up.
I have an xbox and htpc in my living room, a "storage computer" in study, three 11g laptops around the house, one media extender dma2100 in my bedroom.
I want 11n network on my htpc, xbox and dma2100. The way plan to do it is can be best explain via the following diagram.
So is it possible because i am getting incredible deal on 160n routers.
See less See more
Going wired is not an option for me because i live in a rented apartment and don't want to dig the place up because the owner won't be very happy about it. Just tell me if the diagram i posted above will work.
is that all laptops in my house have g wireless adapters. I know N is backwards compatible but would running a laptop with g network adapter and htpc with N network adapter hinder the speed in anyway.[/quote[\\quote]
unfortunately yes it is true. You can not oppperate any wireless with mutliple standards and have then all run at their optimume speeds.
So just like a G access point, if you have B client on a G network G speeds get reduced to B speeds, same goes for N, if you have G clients, the N will get dropped down to G speeds.
Like what was already mentioned, you can get either a dual radio N router (2.4ghz and 5ghz) use 2.4ghz for laptops and everything else and then the 5ghz for the htpc.
The Dlink DIR 655 is a great dual radio router/ap.
another option is keep whatever wireless you have now, and just get a second N router just for the HTPC.
- Josh
just an fyi, if you use a second router as a "cleint" adapter to feed the htpc and 360 don't use WDS mode, WDS cuts through put in half.
- Josh
Not exactly. Yes, you do get drastically reduced throughput, but it doesn't go all the way down to B. Actual throughput of B devices are around 6Mbps, while G devices are around 20~25Mbps. When using mixed mode with a B client (PSP), throughput on the G clients (laptops) drop down to approximately 12~16Mbps which is still better than 6Mbps.
ok yes being a bit over dramatic but you get the point. Your speeds will reduce when using legacy devices was the end point.
- Josh
If wired is not an option - then you have two more options either PowerLine (Ethernet of Power) OR MoCA (Multimedia Over Coax) - option 2 seems to be the best route for you..
Read here for MoCA: http://www.avsforum.com/avs-vb/showthread.php?t=1145636
It operates on the same princple as Verizon FiOS except your creating your own MoCa Network. If you are not comfortable buying from ebay and configuring the Moca routers to become a bridge then you can purchase similar devices from Netgear. So far MoCA is much better and more reliable the powerline. I have personally tested it and get about 85 Mbs throughput BUT for some reason I am still getting stuttering - I am suspecting I have a bad splitter..
Anyways.. those are last 2 options - dont bother with Wireless even N. 5.0 Ghz may be better but is more limited in distance and physical wall/building interference and 2.4 Ghz interferrs with all the G routers/Microwaves/Cordless Phones, etc. - and really dont bother if your running in mixed Mode (G+N) as it pulls down your speed to G speeds which is useless for HD content. I think the guys above have given good feedback... Im still working on my MoCA connection as MANY have had good success... I have not given up.. if that doesnt work then CAT 6 here I come... (sucks but its my last resort). And yes.. I have tried Wirless N - good when in the same room for H.264 but not VC1
See less See more
If ur lucky, some apartment, u have access to the attic. Run the CAT5 there.
All you htpc, Gaming, Media Center Extender Fanatics after intensive research into my issue stated above I have finally come up with fantastic and dirt cheap solution to all my problems and the name of the solution is Netgear WNHDE 1111.
Just Read the following review and you will know what i am talking about.
http://www.cnet.com.au/netgear-wnhde...-339291827.htm
Here is finally networking diagram that i am going to implement. Just beware that Netgear WNHDE 1111 only works in 5 ghz frequency.
See less See more
If your thinking of streaming HD movies it will barely work and thats if your 15m away with minor (not cement or steel) walls.. 55Mbs and higher typically is needed for VC1 or high ref frame movies.. Which based on this review was the max it could sustain - they also didnt talk about latency or jitter which is inherant in wireless networks but adversely affects HD media streaming. Seriously take our feedback and dont waste the $300 plus on these units if your thinking about streaming HD movies.. if its SD, Gaming, Music then they are actually overkill.. Any G will handle this..
Yes it is impossible to stream full bluray rips via wirless. Wrong if you want to stream .mkv's.
Here is a calculation. Suppose a blurage mkv 1080p has a size of 10gb and is 1.5 hours long. The size of the file shall not be more that 10GB.
So
10 GB * 1000 = 10000 Mega Bytes = 10000 * 8 = 80000 Mega Bits
80000 / (90 min * 60 sec) = 14.8 Mega Bits per second
Even with any overhead if the player is setup for proper buffering. Streaming shall be a piece of cake.
See less See more
actually NO it won't be. I am using 2 linksys dma2100's on 5ghz wireless N with a Dlink DIR655 which is one of the best off the shelf N routers/access points out there right now.
I am using the 5ghz side of it for the two linksys extenders, and even with only using one at a time, there are still times I can't get perfect 100% HDTV streaming which is way less than the bit rate of a blu ray/mkv.
you will have marginal success at that.
like others have already said the MOCA solution like this: http://www.netgear.com/Products/Powe.../MCAB1001.aspx
or going the cheap route and buying two actiontec verizon fios boxes and using them for moca bridges: http://www.avsforum.com/avs-vb/showthread.php?t=1145636
those two solutions will be 1000 times more stable, and reliable than wifi.
yes I am using wireless N right now, but I had to tweak it, and the farthest distance I am doing with it is less than 40 feet and on the same floor as each other.
just don't expect miracles is all I am going to say.
- Josh
See less See more
1 - 20 of 34 Posts
