I'm on my second 5065 with 302 firmware. I need advise fast as I must return it tomorrow, Sat. Sept. 27 to get within my 30 day return window at BB. I've got a couple of questions that I know this forum can answer.
1. The fan makes a noise that can be heard during quite passes in audio. I know it's the fan, because when you power down the set it continues, during cool down and, I assume, after the color wheel stops spinning. Is the fan noise a common noise on these sets?
2. My wife sees rainbows and I do not. Therefore, I assume some see it and some do not. Is that the case?
3. Do RPLCDs display rainbows as well or is it a phenomenon with DPLs only?
4. This is an edited question. When I hook up the DVI connection from the set-top cable box, I get the screen that states "Please hook the set-top to a HDTV set." I can see there's a picture behind the screen and get audio. How do you remove this screen?
Oh by the way, just got the hi-def hooked up via Time Warner, OMG is it beautiful! Discovery HD looks like looking out the window, simply amazing. And just hooked up a JVC XV-N50BK DVD player with progressive scan, is this a good player, in your opinion?
Thanks for the replies, my TV depends on them.
Steve
Steve
