Hi there,
I am planning to purchase an Epson 1080UB and I would like a recommendation for a good screen to go with it.
The wall the screen will be mounted on is 96" high by 192" wide. I won't use up all this space, but I am going for a large screen at roughly 150"-160" diagonal.
This will be in a room that does NOT have very good lighting control. A permanently mounted screen is what I'm looking for, not a retractable one.
The room is 20 feet deep. The projector will be ceiling mounted. I will probably mount it in the back of the room, to allow for maximum throw distance with minimal use of the zoom lens that reduces the light output (as I understand it).
According to the projectorcentral.com calculator, I need a 1.4 gain for a low ambient light level environment, or a 2.6 gain for a room with ambient light. These numbers seem high to me, so I'm not sure whether to follow that guidance or not.
Thanks for your recommendations!
-Ed
-Ed
