I have a room of approx 1000sq ft and I will have 3 rows of seating.
I have built large soffits that go around the room and are approximately 9 feet away from the center of the room.
* What are your thoughts on using 9.2 vs 7.2? is it worth it?
* Should I place the speakers in the soffits facing into the room or the ceiling?
* Should I use in-walls or bookshelf mounted as in-walls (bookshelf sort of has it's own backer box)
* What are your recommendations for speakers in the $150-$250 each range?
Thanks...about to start a theater build thread and what like to solicit some of your thoughts....
