1 - 2 of 2 Posts
First post here so I'll try to keep it clear.
Here's what I have:
Epson 3020 projector
HK 1710 AVR
WD media player
Bell Fibe HDTV
I have the projector hooked to HDMI1 out on the AVR
I have WD media player and Bell box hooked to HDMI ins.
When I try to watch tv I get either no picture at all or a compatibilty error. If I bypass the avr, everything works and I have sound coming through the projector. I obviously can't live with this, so please help.
As for the Wd player all works, except sometimes when watching Netflix there is no sound. If I reboot everything normally it comes back.
I've tried different cables, different HDMI inputs, different bell fibe boxes etc. So far nothing works reliably. seems there must be a setup or compatibility issue
Suggestions???
Make sure CEC is turned off if you have it.
Alternatively, run coax/optical digital from
Your 2 sources into the HK. Run HDMI from
Sources into the projector.
1 - 2 of 2 Posts
