Go to BB and listen to one. Easily(last time I was there) the best of the 6 they had on display.
My fav feature of it is it has 3 audio inputs.
Tos-link
Standard red/white
1/8th (would have been nice if this one was on the front)
The only "issue" with it is you need the TV's original remote to program its volume and mute. It won't program from another remote(which makes no sense).
I've tried to program it from a Harmony and a Directv remote. Even when the Harmony and Directv did the volume on the TV, they would not program the soundbar. (and it says so in the manual that you MUST use the original remote, and of course, that info is in "troubleshooting", not in the manual where it would actually make sense to be)
Last time I set one of those up, I plugged it in and "coupled" the subwoofer(out of the box and "playing" takes maybe 10 minutes) I listened to my cell phone on Slacker while I set up the rest of the house. It could be heard two rooms away.
Issues with the manual...(these issues aren't relegated to just this one. But this one has all three...yippee)
Setting up for remote volume and mute could be tons better. I scratched my head the first time, even after reading trouble shooting about the ORIGINAL remote. I've only once(out of 6 of them) got volume up, down and mute the first tries.
The DSP is explained nowhere. It has two modes. "TV" and "music", yet it tells you nothing about which is which. The DSP lights green and "reddish orange"...which DSP is which. I assume "green" is "TV" as that is the color of all "basic" use(meaning Tos-link). The three inputs are nicely covered by three different colors(some soundbars when you switch inputs you just have to wait for a response, this one at least gives you a visual cue)
When it is "at rest" on the Tos-link...if you want to switch to the RCA or 1/8th you have to turn it on first. Which you would think would be obvious by hitting the power button. The first touch of the power button actually turns it off. The second turns it back on, then you can switch inputs. If you push "input" first...it doesn't respond. Nowhere in the manual is this explained.
But those three issues aside(and one actual plus...the visual "input" reference), easily the best sounding $300-$350 soundbar there is. (which sound is the whole point in buying it, isn't it?)
