My Denon 5800 has done it's job for me over the last several years. It worked flawlessly, never had any issues. With no HDMI inputs/outputs, I thought it was time for an upgrade.
I have gone back and forthabout whether to get a separate processor and amp or get a A/V receiver combo. I no longer have a dedicated theatre room, so I figured the smartest thing to do would be getter a higher end 'all in one'.
As I did some research it appears that the Denon 5308 and Arcam AVR600 are popular choices. Trying to figure out what the main differences are which is superior. I don't have an external video processor/scaler and I know these 2units use different ones but not sure if one is better than the other.
My setup is not too complex. Main inputs are HDMI (Blu ray player, Sat box, HTPC from Cellar Cinema) and audio inputs are from HTPC and Yamaha Musicast, and Sonos music system.
Can I go wrong with either one? Is one better for my setup? Does it even make sense for me to consider separate processor and amp?
