1 - 15 of 15 Posts
· Registered
Hi Im new to the forum and need some help with finding a good wireless true HD transmitter and receiver? I know there are a few on the market which claim to out beat one another etc but I figured I'd talk with the experts!
So heres the deal Im currently in the market for a HDMI / Component wireless unit. I have a 58" Panasonic Plasma and kind of difficult to put in wires so I figured this would be my solution to keep things clean but would like to try to get the best HD quality I can! Anyways my component units are going to be at the corner of the room about 5 feet from one another so distance is extremely short!
Here's a few I found so need some insights from you all!
Brite-View BV-2500 - Heard this runs extremely hot!
HD Flow iTrio
Gefen - Over priced
Also Im assuming the best true uncompressed signal is 1080p @ 60 GHz?
Any suggestions would be great!
J5
· Registered
It does run hot. I have my Harmony remote turn mine off and on with the TV as needed. Not sure if it will prolong the life or prevent problems but figured it can't hurt.
· Registered
Discussion Starter · #3 ·
How's the picture quality? Is it pretty clear? Im not sure if its the HD Flow but I remember reading somewhere that the quality on anything higher than 50 inches would show alot of flaws?
· Registered
I have mine running to a 42" Plasma. I use it to watch DVDs and streaming Netflix upconverted to 1080i, and output from my SD DirecTivo upconverted to 720P. Will be getting an HD DirecTV box in the future. I haven't gotten around to trying a Blu-Ray yet. The DirecTivo and the Netflix looks quite good and the DVDs look great.
· Registered
Each unit has a 5V, 3A (15W) adapter power supply, so that amount of power dissipated in the units can generate significant heat. Turning them off when not using likely prolongs their life (along with saving a few bucks on your power bill
· Registered
Discussion Starter · #7 ·
Im told it works great with anything 50" and less from what I read. I cant find anything that states anything about 50" and which wireless unit is the best signal?
· Registered
Discussion Starter · #8 ·
· Registered
If a digital picture looks good on a smaller TV (without any obvious artifacts or dropouts) then that is a good as it gets. It will also look fine on a large TV. There are no subtle degradations in a digital picture that would show up only in a larger display (assuming the signal is not being compressed by the transmission system, which I believe the BV-2500 does not).
· Registered
I'm using the HDFlow iTrio - 100W from the transmitter co-located with an STB and 1080P screen, across the house and up one floor (old construction, metal lath in walls) to a 1080P (1900x1200) screen/monitor.
The iTrio signal is rock solid and using a Monprice HSP-102M active HDMI splitter I can simultaneously utilize both 1080P output devices without any HDCP or DRM issues. Using the IR blaster allows remote channel change.
Pretty slick for $199.
· Registered
Discussion Starter · #11 ·
Sorry for the late response. As for the transmitter I believe the BV-2500 is discontinued and was replaced by the BV-2322 is there any difference between the two?
· Registered
Discussion Starter · #12 ·
The iTrio for its price is not bad either so Im currently debating on the iTrio or the Brite-View. Where did you buy the iTrio for $199?
Also how many ports are on the back? Im looking for something with both HDMI and Component plugs. This is true 1080P as well right?
· Registered
Originally Posted by WynsWrld98 /forum/post/19746227
How does this product relate to the iTrio?: http://hdflow.com/Features/index.html
Has HDMI, Component and Composite IN, HDMI and Composite OUT. HDMI and Component are 1080p, Composite is VGA.
Overstock and eBay are your friend.
1 - 15 of 15 Posts
