I have a bit of a unique situation I need help with. I have a trailer that I use for a mobile motel room when working out of town. I need some type of video entertainment to keep me occupied at night. I was going to use a flat screen tv in it, but my wife bought me a Smart Beam Laser Projector, and rather than hurt her feelings, I want to figure out the best screen material to use. It can be actual material or a painted surface. the screen is going to be 50" to 60" max diagonal. Based on info I got from the mfgr, 50" is the sweet spot for this little guy. Here is the info on the projector. Any help will be greatly appreciated. BTW - the mfg says the screen should not be matte, but slightly reflective. It will be mainly used for OTA TV via a HD TV Tuner Box.
http://www.uobeam.com/
Dimensions 2.2"x 2.2"x 2.2"
Laser Diode Life 10,000 Hours
Brightness 100 Lumens Max
Resolution WXGA 1280 x 720
Throw Ratio 1 : 1.428
Speaker 1 Watt Mono Speaker
Battery Capacity 3.7V 4200 mAh
HDMI Input Micro HDMI
Laser Class Class 1
Battery Life 120 minutes
Aspect Ratio 16 : 9
Throw Distance 2 ft. ~ 15 ft.
Screen Size 20 inch ~ 150 inch
Contrast Ratio 1000 : 1
Battery Life Approximately 120 minutes w/4 hours full charge
Battery Type Rechargeable Lithium Polymer
Optical Engine Type LCoS (Liquid Crystal On Silicon)
Wireless Display Android / iOS Mirroring
Laser Class Class 1
Aspect Ratio 16 : 9
