Amorg,
I don't have your need for a mic or lighting system, but I have decided to go HD. And for that I bought the HF100 and a 16Gb SDHC card. The 100 is the same as the 10, but without the memory (and the case is silver and not black) and is a bit cheaper.
I currently have a Sony PC100E DV camcorder and decided to bypass the HDD versions as an HDD will eventually die on you (needing the camcorder to be replaced, or the like), whereas if a SD card goes, you toss it out and replace with a fresh one.
Not sure on the editing stuff. I have Ulead Movie Factory 6 plus the HD add on. Not bad.
Hope that helps
Seggers
Amorg,
Hope that helps
Seggers
