I have an old (circa 2001) Bose Lifestyle 12 ls12 system that I want to upgrade. Pics and some somewhat inaccurate specs here:
http://www.dealtime.com/xPF-Bose-LS12
I think the bass is just muddy, and it doesn't support DTS in spite of what that page said. Plus I want to get a new sound system that supports the new lossless formats.
I don't want to spend very much on this project, probably less than $500.
From the look of things, I should be able to salvage the 5 satellite speakers that came with the bose as they are compatible with normal speaker wire, and they may be of decent audio quality (unless somebody else here disagrees and thinks I should just start from scratch?) Everything else is more or less junk as it is based on proprietary connections and controllers.
So I guess I am going to need a new sub and a new receiver, hopefully one that can produce good sound through the bose satellite speakers for the time being, until I can eventually replace them later if necessary. As for the receiver, I want something that accepts two or more of the following of each: coaxial, optical, hdmi, and also at least one set of 6ch analog inputs for my HTPC. Adat would be nice as my HTPC supports it, but AFAIK no ADAT receivers exist for the home theater setup.
Radio tuners and built in cd-players are not needed as I wouldn't use them (this kind of audio is always sourced from my PC) but I don't mind if it has them anyways.
Anybody have any idea of where I should start looking? BTW I am not picky about brands just so long as it produces decent sound.
Also, I was also considering just getting rid of the whole thing and buying a logitech z-5500 instead. How would this compare to the setup I am looking at with a
Thanks for any guidance anybody can provide here.
