1 - 2 of 2 Posts
This september me and my mates will be moving into a house for second year university. We entertain a lot at the moment having flat parties however usually get asked to turn the music down  within an hour of starting since we are living in flats at the moment. When we move into a house this year that shouldn't be a problem anymore. Anyway my question is that at the moment we're using some £40 logitech speaks with a small subwoofer and it can do the job but it just doesn't feel loud enough. So we want to buy some good quality and LOUD speakers enough to fill a decent sized living room and be heard down the hall way.
Budget is around £150. The music will be played from a laptop using spotify.
I would appreciate specific model speakers.
Premium Member
For parties you should consider PA speakers or powered monitors. I would recommend the Behringer Truth 2031 (powered monitor) or the Behringer Eurolive series (active monitors).
  • Like
Reactions: iamnotatree
1 - 2 of 2 Posts
