Why not just boost the midrange using an equalizer?If you really like the planar magnetic tweeter, but want a stronger midrange like the EMP, what speakers would you look at next
Well that begs the question - is that really the same?Why not just boost the midrange using an equalizer?
Maybe I'm finding I don't like the sound of flat speakers.Are you claiming that the Arx does not have a good midrange?
Audyssey seems/may be adjusting for room modes and floor bounce in that range - which canMaybe I'm finding I don't like the sound of flat speakers.
I'm using Audyssey and the midrange is boosted substantially, from 4 to 8db between 300-600hz or so. But I'm not sure that gives the same result as a speaker that's tuned to exhibit that naturally.
Yup the EMP is definitely boosted a bit in the range of dialogue, bass guitar and the lower piano notes and drums, which makes the flat Arx sound more lifeless without correction. It's really easy to spot these differences when you have both speakers to compare.Auddyssey seems to be adjusting for room modes and floor bounce in that range - which can
tend to happen with towers in a lot of rooms - and can depend on the towers driver placement.
Also the EMP can dip/bounce between 200 to 300 hz - and tends have a bump (built-in) in the
midrange of around 5 db between 1 and 1.5 khz.
It all depends on your taste and preference - it is what floats your boat.
None of that really matters, but we're talking spare bedroom, Denon X4000. I'm just wanting to know if there is a speaker that would combine the attributes of a really good midrange like the EMP with a killer tweeter like the Arx has. If not, I'll be happy with what I have, but I've been bitten by the speaker bug and I want to hear more.While we kind of understand what you mean, the amount of information you've given us is not even close enough to what one would need to give wise recommendations.
Budget? Room? Have you tried different EQ's on both speakers? Size limitations? Listening habits? Powering them with?
I believe those aspects do help.. You wouldn't want me to recommend a huge 1000$ speaker for your bedroom. How else would I know what direction to send you in? Just because you have two similar sets speakers to base what you 'want' from a speaker doesn't mean we know what you want. Combing two attributes of two speakers many people haven't probably haven't had the chance to listen to side by side like you have isn't easy. Are you trying to jump up a a couple floors? Or trying to spend around the same cash?None of that really matters, but we're talking spare bedroom, Denon X4000. I'm just wanting to know if there is a speaker that would combine the attributes of a really good midrange like the EMP with a killer tweeter like the Arx has. If not, I'll be happy with what I have, but I've been bitten by the speaker bug and I want to hear more.While we kind of understand what you mean, the amount of information you've given us is not even close enough to what one would need to give wise recommendations.
A larger Bookshelf-Then I should clarify. The way I shop for things tends to be different than most. I like to see what's out there first, do some research on them, then compare products and see what I really need and what's worth it to me. I don't tend to set a strict budget because it can artificially limit what you see. With that said, let's say I'd like to not spend more than $1000-1200 for a pair. I tend to also prefer floor standing for the stability of the built in stands, but do not need extremely deep bass output. Rythmik subs will be used as soon as I can order them. That's one reason why the A3rx-c stood out to me over others, where I felt large woofers would be a waste of money if I wasn't running them full range.
What do I feel is missing? A natural timbre from voices. It's close, but only with Audyssey. Without it, people sound like they are "trapped in a speaker cabinet" so to speak.
No, but with the amount of recommendations and info about them, I have no issues saying that."Pretty handily destroy"
That's a very interesting statement. Have you heard the two speakers in question? I will look into all three of those you mentioned, thank you.
I know you said music is top priority, but this will give you an idea of what they can do at lower levels.Hmm...
http://reaction-audio.myshopify.com/blogs/news/15338885-speakers-and-more-speakers
I'm wondering how these Radian drivers sound at lower volume levels? I never listen at reference. And music should be considered top priority. Get that sounding right, and everything else - movies, gamebs, etc, is icing on the cake.
I'm going to do some reading in the Reaction Audio thread.
