1 - 2 of 2 Posts
Hi All-
I am still debating upon a new receiver and have narrowed my search down to 2 models- the Elite SC-25 or the Elite VSX-23TXH.
The receiver will need to drive to Sonus Faber Grand Pianos (Concert Home Series). I think it is pretty much a no brainer that the SC-25 will provide plenty of power- but will the VSX-23XTH provide enough horsepower, or will i be disappointed?
Here are the specs for the 23TXH
110 Watts x 7 Direct Energy Amplification
(20Hz - 20kHz, 8 ohms, 0.09% THD - FTC)
Here are specs for the Grand Piano's:
Type: 30 litre two-way with ABR front vented design, magnetically shielded
Tweeter: 26mm silk dome ferrofluid cooled
Mid and Bass Driver: 180mm fibre glass multi-coated cone
Frequency Response: 35Hz - 20kHz
Sensitivity: 90dB/2.83V at 1 meter
Nominal Impedance: 6 ohms
Crossover Frequencies: 200Hz, 3kHz
Maximal Power Handling: 250 watts
Dimensions: 1080mm x 235mm x 290mm (HxWxD)
Weight: 25kg each
Any help appreciated- Thanks all!
It's hard to say how much power a receiver has from it's specs. Power drops off as more than two channels are driven, and the specs of this receiver don't reflect this.
Given that it's Pioneer, and they have been a good company, and it's not a budget receiver, I would expect good performance.
1 - 2 of 2 Posts
