I wasn't sure which forum to post this in so I hope you guys can help.
My wife is setting up a new office which is a health center. She needs a speaker set up for 6 rooms, and in ceiling should be easy (since it's ceiling tiles).
She is basically looking for something that is cost effective, that enables them to play the same music in all the rooms but also to have individual volume controls. Preferably, there should be volume control in each room but the main music receiver/amp will be in the reception area.
Wired or wireless is fine. I've found some options but it seems the volume control would have to be at the reception area too.
I was thinking of getting her some cheaper monoprice ceiling speakers and wiring them to a multi-speaker output at the reception.
Otherwise, perhaps individual wireless speakers in each room with it's own input.
I'm honestly not sure what the best solution is. The farthest room is about 30+ feet away. I think a wireless hub might also work, if there are speakers with individual controls.
Anyone with experience that can chime in with options/solutions?
