I am looking for a high quality spade plug and a high quality banana plug. I will be using these on both ends of the wire, but do not know if I will use a spade or banana at this point. I would like high quality suggestions for both that I can check out. The bind posts on my sherb 7/2100 are pretty close so bare wire is a pain. My s-38's are better but would like the clean connection of a spade or banana.
Also, my rear speakers are flat against the wall and it seems a banana would stick out to far to use for these. Would a spade work for these?
