Hi All, I am looking for help and recommendations with my Home Network.
I am good at building computers, but have lots to learn about networking. I hope some of you will take the time to read this post and make some suggestions. Since my layout is rather large and confusing I am trying to include as much info as possible in this post. Thanks in advance for any help.
Here is a rundown of the layout.
My whole house is wired in Cat 6. Everything is wired, no wireless. All equipment runs to the 24 port switch.
Location - Hall Closet:
AT&T Uverse Gateway Made by 2-Wire, Model Number 3800 HGV-B. We have 24 Mbps Internet Service.
Netgear JGS 524 Unmanaged 24 port Gigabit switch.
42 Terabyte Server running Windows 7 64 Bit Professional. ( Details Below )
QTY> 3 Silicon Dust HD Home Run Dual Tuners for a total of 6 ATSC Tuners.
Location - Home Theater:
Home Theater PC running Windows 7 64 Bit Professional
XBOX 360
Location - Den:
XBOX 360
Location - Office:
QTY>2 PC Running Windows 7 64 Bit Professional
Location - Master Bed Room:
XBOX 360
Popcorn Hour C200
Location - Kids Room:
XBOX 360
All the equipment above works fine. The problem I am having is fine tuning the network for more bandwidth and higher speeds. The 42TB server is where I have the bottle neck.
All the straight up PC's have no problems and do not seem to contribute to the problem as they do not use or stream from the Server. The 4 XBOX 360 units do not contribute to the problem if they are just being used for online gaming.
The Home Theater PC, Popcorn Hour C-200 and all 4 XBOX 360 units do stream from the server. The server is the main Windows Media Center PC. It holds all our DVD' , Blu-Rays, Music, Pictures as well as has the 3 HD Home Run Dual Tuners configured in Windows Media Center.
We have 4 Television sets in the house. If I am only using one of the above units as a media center extender I have no issues. When adding a second unit, if both are streaming High Definition Content, 50% of the time there is no problem. It depends on the Content and Audio. Once the third unit is started you get Screens freezing, Stuttering, Loss of Audio, Loss of Picture, etc... If I shut down one unit immediately the last two will recover and continue normal operation. Otherwise they will crash and you need to either reboot or go out to the main menu and start again. The first one to crash when multiple units are running is always the PopCorn Hour C-200 if it is streaming a Blu-Ray.
Here are the specs of the 42TB Server:
Windows Professional 64 Bit Running Media Center, Intel S3210SHLX Server Mother Board, Intel XEON E3110 Wolfdale 3.0GHZ Dual Core, 8 Gig of GEIL Memory, QTY- 21 - 2TB SATA Drives, QTY- 2 - SUPERMICRO AOC-SAT2-MV8 64-bit PCI-X 133MHz SATA II (3.0Gb/s) Controller Cards, Sony Optiarc Slim 8X DVD±R Burner Black SATA Model AD-7590S-01.
The Intel Board has two onboard Gigabit Ethernet Ports ( I am only using one ) I am using the onboard video and no sound. This unit stays in a air conditioned closet. All units have static IP's.
OK, Here are my questions about the server and network.
1. What would be the optimal settings in Windows 7 Professional for the network and each unit for maximum speed and bandwidth?
2. Can I Team up the Two Onboard Ethernet ports on the Server to act as one? ( I think the two ports are different. They are both listed as Intel Gigabit ports, but have different model numbers. One is Intel 82541 and the other is Intel 82566.
3. Can I add more Ethernet Ports to the Server Board?
4. Would a higher end managed switch make a difference?
5. Should I upgrade the server to Windows 7 64 Bit Ultimate to get NFS file sharing? ( This may work much better for the Popcorn Hour than Using SAMBA )
6. What kind of tests should I run to help find out how to fix this?
If you need more info , Just ask. Please remember Networking is not my strong suit. Please explain it to me as simply as possible.
Thanks for any help,
Chris
XBOX 360
Location - Den:
XBOX 360
Location - Office:
XBOX 360
Popcorn Hour C200
XBOX 360
Chris
