1 - 3 of 3 Posts
I have existing wiring I'm try to re-use for my new HDTV in the kitchen.
I have currently running:
3- RCA jacks
1- coax
1- S-Video
I'm using the COAX for off-air antenna, so it's good.
I'm using the 3 RCA jacks for normal composite/audio for rebroadcasting the output of my Tivo at std def.
The s-video is unused.
What I'm wanting is to get a hi-def signal from the Tivo to the new TV using the existing wiring.
What I though I could do was:
1) repurpose the 3 RCA jacks to component video
2) multiplex/demultiplex the s-video cable (not signal) to RCA audio cables (r/l)
I don't need anything more than 2 channel audio since it's a kitchen TV.
The 4-pin s-video seems like it has enough signal to get me 2 audio lines, but I can't seem to find an adapter. I found 7-pin s-video adapters, but I only have the 4-pin connectors run.
The cable run is short (about 20 ft)
Anyone have any ideas on how to wire this up to get an HDTV signal using EXISTING connectors?
2 channel audio with a 4-pin s-video should work fine. You may need to make your own adapter though. I don't think I've ever seen one for sale.
If you're handy with a soldering iron, it shouldn't be hard at all.
S-video pins 1 and 3 for left channel, pins 2 and 4 for right channel.
1 - 3 of 3 Posts
