I really need your advice on trying to decide between the Denon 891 and the 791. Here are the devices that'll be hooked up to the receiver...
-PS3,360,Apple tv, DVR, and possibly a PS2, Original xbox, and a nintendo wii.
Things I like in the 791
-300$ cheaper than the 891
-Same sound quality as the 891
Things I dislike in the 791
-not enough Inputs for my older systems and less HDMI connectivity for future use
1.So my questions are...Is it worth the 300 bucks for the extra connectivity in the 891?
2. Is the Anchor bay chip in the 891 a good upgrade if I decide to go with it and have my older systems hooked up at all times??? or will the 791 and it's upscaling chip be fine If I have to physically switch my older systems from time to time?
I would like to stay around the 500$ range but if it's worth the 300 bucks with the 891 and it's connections then then I guess I would be willing to go that route. Thanks!!!
