As the title says, I could use your expertise and assistance with a projector installation. This will be my second projector. The first, a Sharp Sharp XV-Z12000 MKII, was installed by a friends son who had a significant amount of projector, and home theater installation experience. He was in a rush due to another comittment, so it was not as though I had much opportunity to observe his work.
My room is thus, already set up and awaiting the installation of a just arrived, and much awaited JVC RS20 that I was fortunate enough to be able to pick up on a great deal from AVS as a refurb/B-stock unit.
It's the basic physical installation details that I am not entirely certain of, but hopefully the fact that everything is ready for the new projector will make that an easier task.
The projector will sit on a custom built shelf enclosure that is on the opposite side of the wall, in another room, allowing the projector to send its output into the home theater room through an opening in the wall, as in a movie theater.
The other room specifics are as follows:
projection distance - 15 feet
shelf height - 56 inches from the floor
110 inch screen
Any assistance in how to correctly physically install the projector, and get it initially working with an image on the sceeen, would be a tremendous help.
Once installed and working, I will then be trying hard to closely adhere to Art from Projector Reviews recommended settings for the RS20:
http://www.projectorreviews.com/jvc/...alibration.php
John
110 inch screen
John
