Originally Posted by Art Lloyd /forum/post/18115836
Neighbor has a newly assembled front projection HT. When his subwoofer plays loudly the receiver shuts down. I have no idea why this happens. It is not a matter of the circuit breaker. The receiver goes into its idling mode. Does anyone have an idea what might be the cause?
A couple of things to check..
Are the subwoofer and AVR connected to the
same AC outlet circuit?
If YES, then the subwoofer when a heavy bass signal hits may be drawing down the AC line voltage. If the AC voltage to the AVR
sags enough just for a split second, then the AVR may go into Stand-By. This also could happen if the house has older electrical wiring, with lower current capability. Additionally if some other applinace or component is connected to the same AC line circuit this may cause the voltage to sag as well.
Just my $0.01..
