Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
I have a new Mitsubishi WS-65413. I've programmed NetCommand to control my other components, but I'm having trouble getting it to power them on/off. All the other functionality works (that I'm using), but I can't seem to get them to turn off & on. Each time I hit the power button on the remote, the TV turns off.
Does NetCommand support power on/off of the other devices?
Mike
it works fine for me. it's very cool because when i turn off the TV, it turns off the receiver and DVD player automatically as well (and vice-versa). it would be best if you have components that support discrete on/off like the denons. first, make sure that your IR emitters are connected to the NetCommand IR port instead of the IR repeater one. then, make sure NetCommand has learned the on/off signal of your component(s).
1 - 2 of 2 Posts
Status
