Not likely. Unlike the Belkin, the Netgear doesn't support WDS bridging. However, *if* the Netgear has AP client mode, you may be able to use the Belkin as your router and connect the Netgear to it as a wireless client. This is iffy at best.
Originally posted by j.m. *if* the Netgear has AP client mode, you may be able to use the Belkin as your router and connect the Netgear to it as a wireless client. This is iffy at best. |
Originally posted by sfhub Many implementations of AP client mode end up with a proprietary mode where the AP needs to keep track of the MAC addresses sitting behind the "AP client" and requires specific support in the AP to work properly. On the other hand, with MAC masquerading bridges (which BTW I'm not advocating, just comparing against) the bridge/client keeps track of the MAC addresses itself, so there is no support needed on the AP side, and it will theoretically work with any AP. |
