http://www.twice.com/article/449518-...Components.phpQuote:
Netgear plans to launch two wireless adapters that wirelessly connect Ethernet-equipped home-theater components to the Internet to stream high-definition video, audio and other content.
The devices can be used with any brand of Ethernet-equipped game console, TV, Blu-ray player or A/V receiver designed to stream Internet content.
One of the two new products, the Wireless-N HD Home Theater kit, consists of two Wi-Fi-certified 802.11a/n adapters capable of delivering multiple, simultaneous, jitter-free 1080p HD video streams wirelessly.
One adapter can connect to two Ethernet-equipped CE devices at a time, thanks to the adapter's two Ethernet ports. The other adapter connects to the Ethernet port of any wired or wireless home-network router. Both adapters must be plugged into AC. Additional adapters are available separately to plug into additional CE components in the same room or other rooms. Each adapter is 6.9 inches by 5.1 inches by 1.4 inches.
It's promoted as the only solution that provides sustained throughput of HD streams exceeding 40 Mbps 99.9 percent of the time through multiple walls in an above-average single family home, the company said.
