1 - 1 of 1 Posts
Last night, the S70 begin asking for the Nevo Connect to be found again (no worries, it has done that before)... went down to the NC-50, followed the on screen prompts for it to "Add Node" and it repeatedly says something to the effect of:
B9448E.5 successfully added. Had requested Main Controller. Please add it next.
B9448E is listed as the Home ID of the Primary Controller (which shows the same Nevo ID as my S70). The Nevo ID of the NC-50 (Main Controller) is different.
Why is it confused?
I've reloaded my configuration, tried factory resetting the NC-50 to be "blank", now I'm thinking about trying to reset the S70 and reload from there.
Can't figure this out.
1 - 1 of 1 Posts
