Status
Not open for further replies.
1 - 8 of 8 Posts
Do you guys any tips and tricks that I should be aware of?
I have a mitsu 65907 just crying out for some HD.
What is the best way to hook up my uhf antenna to the ota module?
Thanks in advance,
Ray
Discussion Starter · #3 ·
One more thing...
How do I hook up the audio portion of the dish 6000?
I would like to hook it up to my denon 3801. Is an optical cable the only way to go?
Originally posted by MichaelH:
Lastly, use high quality RG-6U coax, (preferably with quad shielding) and don't forget to ground!
This is a stupid question, but exactly how do you ground an antenna? I will be installing a 6023 and a yagi for terrestrial HDTV soon. I'll be running RG6 that doesn't have a seperate ground wire.
Do I need another wire for ground? Or do I just ground the shield wire?
The ground stake for my phones/electrical box are on the other side of the house, do I just pound a metal stake in the ground and ground to that?
There is some galvanized steel piping near where I want to ground . . . but it is for the natural gas line. I assume that grounding the antenna for lightning strikes to the gas line is *not* a good idea. ;-)
"Don't use diplexers in running coax from the sats and OTA. They all stink and seperate cable runs aren't expensive if you are installing yourself."
I ran diplexers down from my setup and haven't had a problem with them. I bought the Rat Shack flavor that cost $25 each but was able to find them on sale at half price online back in January. They work great!
Originally posted by raze:
One more thing...
Absolutely. Not only will you get Dolby Digital (when broadcast), but even for mono and stereo the D/A converters in your Denon are better than those in the STB.
You can use another ground rod, but you must connect the new rod to the main ground rod using a 6g green wire to meet code.
Glenn
1 - 8 of 8 Posts
Status
