1 - 7 of 7 Posts
Discussion Starter #1
Hi All,
So I have been researching a ton on a DIY Sub build for my HT. I am 80% movies, 20% other.
The room is dedicated DD+GG+Clips. rough dimensions 19' long, 15' wide, 8.6' H at soffits all the way around.
I have a Dayton UM15-22 woofer and Xli-1500 with mini-dsp. Denon x4500h avr.
I am handy (doing the room build myself) but I am just learning sub box building in real time.
I want the sub to deliver strong low end but I dont need to break everything in the house. BTW the room is on a concrete slab. Also I plan on using MDF and Plywood for the second front plate. I have been studying the devastator, marty etc..
I have been playing with WinISD and subbox.pro.
I am not sure what I should tune the box at, too many variables. Im looking for a safe number for my first box. I can always build another in the future. I was just going to do a front facing slot with the woofer. I can go upto 42" long x 28" tall x 24 D. It will be in the front of the room under my AT screen 12' from MLP.
Any advice is welcome.
I thought I would have the same listening habits as you. I ended up going with a mini Marty because I wanted to focus on the low end. I went with the 18" version of the one you have. I like it a lot but I wish I would have known more about the devastator at the time, I can definitely tell it lacks in the mid bass and I find myself listening to more music than I thought I would. Not super familiar with how well that 15" pairs with any of the devastator designs, but if any fit your constraints I'd pick that or marty variant.
The condensed answer is:
20hz gets you like 90% of movie frequency coverage.
15hz gets you like 95%, 25-30hz gets you 80-85%
1-15hz is the last 1%, and will require a 1%er budget
Plan accordingly...
The lower you tune, the less efficient the mid-bass will become. Make it have less chest-kick (which is like 40-300hz.)
Due to that effect, a 1hz tuned box is basically a sealed box, they practically measure the same SPL in most cases.
The total power (watts) is spread evenly across all frequencies i.e. more thinly.
If you want 180db @ 90hz in a cement truck, then a narrow 6th order ported or horned box will get you near the world-record.
If you want all the frequencies, then you'll have low efficiency like a sealed box.
There is no free lunch.
Every design has different advantages and disadvantages, it's just a matter of know what you can/can't live with/without.
IB and Sealed has good 1-10hz performance and phase response, while keeping the box small.
Ported is more efficient near tuning, and a steep rolloff, port noise and requires a HPF.
Horned is comparable, but roughly ~6db louder than ported or sealed at all frequencies above tuning, larger, MUCH more complicated, and an even steeper rolloff, often limited bandwidth and uneven FR and bad phase/group delay figures.
Many subwoofer horns struggle going much higher than 120hz, where as all the other box-types go up to 200-300hz or whatever.
Discussion Starter #4
Ok interesting. I have seent eh Devastator and I think there is a Micro Dev I can look into.
Discussion Starter #5
Plan accordingly...
This is a awesome summary. Since I already have a UM15-22 and I have a Crown XLi1500 I want to work within those boundaries. So I have been working in WinISD trying out different combos. I dont care if it is round verse rectangle vent.
I am looking at the Johnny vs Mini Marty as examples. I was thinking of tuning in the 18-20 range. I will have around 24" deep if I don't want it sticking out too far into the room from under the screen.
Under the screen I will have roughly 30" to play with. Length is where I can make up for the extra space, so I can probably go upto ~10cuft.
So if I run these through WInISD with the following settings: UM15-22 Driver, 450W Signal, 1 Vent @ 2.5x24x38.2. The biggest thing I am wondering about is the port velocity looks like it might be too high start at 23Hz. Since I am new to this, not sure if I need to control this better.
Also based on my specs any recommendations if there is a box I should mimic more.
Don't forget to add the HPF in WinISD. That will tame the port velocity as well as the excursion.
1 - 7 of 7 Posts
